Now, I've been learning Verilog but I got stuck with some easy problems.
always@(posedge clock)
if(reset == 1’b1) leds_r <=0;
else leds_r <= leds_r + 1;
I can understand if(reset==1'b1)leds_r<=0;
but the matter is else leds_r <= leds_r+1;
what is that means?
I activated that with only always@(posedge clock) leds_r <=leds_r+1;
code
using Spartan-3A/AN Starter Kit Board then, after I pushed reset button, all the leds were cleared.
leds_r
changes from whatever value it had to one more than that. It's the usual way to express a counter in Verilog. \$\endgroup\$<=
means non-blocking assignment. I.e. it is basically saying incrementleds_r
by 1. \$\endgroup\$
