-1
I was interested in the "wireless" pins technology used on this here: roli blocks(music)
Would be much appreciated if you could guide me towards some modules/components or the name of such tech. Or something similar for future projects.
Also, it would be helful with some tips as to finding components in the future when I don't know the names of them.
Thanks.
EDIT 1: Component website
closed as unclear what you're asking by Olin Lathrop, laptop2d, RoyC, uint128_t, Harry Svensson Apr 23 '18 at 19:03
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ is there a website for that device? \$\endgroup\$ – jsotola Apr 13 '18 at 20:32
  • \$\begingroup\$ found it ... next-startup.com/the-building-blocks-of-electronic-music \$\endgroup\$ – jsotola Apr 13 '18 at 20:35
  • \$\begingroup\$ roli.com/products/blocks \$\endgroup\$ – user2453885 Apr 13 '18 at 20:38
  • \$\begingroup\$ Huh? Without explaining what this thing does or even what purpose it has, this is a non-question. I might be willing to follow a link for more details, but the basic information needs to be here in the question. \$\endgroup\$ – Olin Lathrop Apr 13 '18 at 20:52
I haven't used these, but I believe the units are held together with magnets and little spring-loaded contacts touch when the units are brought together, allowing those contacts to transmit data.
It's not a standard. It's just a clever mechanical way of wiring things together.
See Apple MagSafe and Snap Jacks cable. It's all proprietary connectors, but the magnets are separate from the data/signal/power transmission.
    \$\begingroup\$ I think that the explanation of @schadjo is correct. Looking at the picture the pogo pins came to my mind. \$\endgroup\$ – Kitana Apr 13 '18 at 20:55
  • \$\begingroup\$ Thanks for the help guys. You're surely more helpful than the "pros/veterans". \$\endgroup\$ – user2453885 Apr 14 '18 at 10:56
