I'm trying to send parallel 8-bit data serially. When Send is 1, it should start sending data. It is shown in the below figure. enter image description here
module transmitter(Clk, Send, PDin, SCout, SDout);
input Clk, Send;
input [7:0] PDin;
wire reg [7:0] PD;
assign PD[7:0]= PDin[7:0];
output SCout;
output reg SDout;
always@(posedge Clk)
    PD[7:1] <= PD[6:0];
assign SCout = Clk;
always@(posedge SCout)
    if(Send== 1'b1)
       SDout <= 1'b1;
    else
       SDout <= PDin[7];
endmodule
Here,
wire reg [7:0] PD;
it throws error.
Error (10170): Verilog HDL syntax error at transmitter.v(4) near text "reg"; expecting an identifier ("reg" is a reserved keyword ), or "[", or "signed", or "unsigned"
I didn't use PD and had shifted PDin in always block before, however, it said PDin cannot be both input and reg. Therefore, I've updated the code as in the above.
    \$\begingroup\$ wire reg [7:0] PD; You can't have a signal that is both a wire and a reg. In case you are wondering how to find that, I looked at line (4) for text reading reg, as stated by the error message - it's telling you that reg is unexpected (a.k.a. not allowed) at that point. \$\endgroup\$ – Tom Carpenter Apr 13 '18 at 19:52
    \$\begingroup\$ assign PD[7:0]= PDin[7:0]; You can't assign a reg using an assign statement. \$\endgroup\$ – Tom Carpenter Apr 13 '18 at 19:52
    \$\begingroup\$ For readability, all of your if, else, and always statements should have begin and end. Just like in C where you have { and }. \$\endgroup\$ – Tom Carpenter Apr 13 '18 at 19:54
  • \$\begingroup\$ If you want to perform some action (e.g. sending data bits) on and event (e.g. a signal going high), built a state machine. \$\endgroup\$ – Tom Carpenter Apr 13 '18 at 19:56
  • \$\begingroup\$ For Asynchronous serial communication Start = "0 and "hi for RS-232 \$\endgroup\$ – Sunnyskyguy EE75 Apr 13 '18 at 20:11
First lets look at the error message.
Error (10170): Verilog HDL syntax error at transmitter.v (4) near text "reg"; expecting an identifier ("reg" is a reserved keyword ), or "[", or "signed", or "unsigned"
On or near line 4 there is an error - near to a bit of text that reads "reg".
On line 4 we have wire reg [7:0] PD; - I spot the text "reg".
After the wire keyword, you must either give an identifier (the name of a wire), or a [ (in case of a multi-bit wire), or specify whether the wire is signed or unsigned (default). Instead you have used a reserved keyword reg.
Next, assuming you intend PD to be a reg, the line assign PD[7:0]= PDin[7:0]; is also an error - you can't assign a reg using an assign statement. If you intended PD to be a wire, then you can't use it in the always block later on.
I didn't use PD
Yes you did, you used it as the target of both a procedural assignment, and a continuous assignment. So you did use it. And in a way that is not allowed (see above).
As a third point, for readability, all of your if, else, and always statements should have a begin and an end keyword. You use begin/end in the same way you would use {/} in C. It might seem tedious, but it is good practice and will save you time in the long run.
As a final point, if you want to perform some action (e.g. sending data bits) on and event (e.g. a signal going high), you should look into building a state machine to control the flow. Remember that everything you are describing with Verilog is hardware (hence HDL), so if you want to perform a sequence of actions, you need a hardware construct which does that - a state machine is one example.
