I have designed a custom library component in altium. I have done both the schematics and the footprint. Made sure that the PIN designators are matches in the schematic and footprint. Assigned that footprint to the schematic. Now when I try to import the changes to the PCB all components are added except this one. I have taken some screenshots of the component. If you need some more information, do let me know..
enter image description here enter image description here enter image description here enter image description here
    \$\begingroup\$ Our buddy, Asmyldof, from the EESE has a dedicated chat room for Altium related questions. Try asking here. Going into his chat room is like waking up a tired god that's been sleeping for a thousand years. \$\endgroup\$
    – user103380
    Apr 13, 2018 at 22:44
  • \$\begingroup\$ Did you "Update all schematics" with this particular component. ? \$\endgroup\$
    – Mitu Raj
    Apr 13, 2018 at 22:48
  • \$\begingroup\$ Hi @MITURAJ, I have this component only in one place and yes updated it.. Trying to update again and again :( \$\endgroup\$ Apr 13, 2018 at 22:50
  • \$\begingroup\$ Have you actually imported the Footprint into the Schematic component as a linked item? If all your pins are named correctly it should find the links if the footprint was linked to the schematic symbol. Most common reason for it not to is that you forgot to do that. And @KingDuken made me laugh. Edit: Saw your picture of the footprint model... Thinking while brushing my teeth. \$\endgroup\$
    – Asmyldof
  • \$\begingroup\$ Hi @Asmyldof, Yes, I did, I have posted the screenshot of that as well. I am you altium chat room, can we please talk there? I can send you information quick there.. \$\endgroup\$ Apr 13, 2018 at 22:52
Problem solved.. Asmyldof pointed to it.. Altium did not like the "Space" in the component name. Removed the space, replaced with "dash", removed the footpring from the schematic, added the footpring back, removed the component from schematic, added back and Altium happily added it to the PCB.. :)
  • \$\begingroup\$ Good catch..... \$\endgroup\$
    – Mitu Raj
    Apr 14, 2018 at 3:37
