-4
I'm trying to recreate parts of a rv control panel for replacing it with the raspberry pi, but I have a hard time figuring out what these parts are. the black one reads "T8-2-472G" and the red one "L5|S332 817" I guess they are some kind of multipack capacitors but I can't find anything about them. enter image description here
closed as unclear what you're asking by Olin Lathrop, Harry Svensson, Michel Keijzers, Finbarr, Voltage Spike Apr 16 '18 at 15:15
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ yeah, I didn't manage to get the components in focus with my phone ;-( \$\endgroup\$ – low_k0 Apr 15 '18 at 15:40
    \$\begingroup\$ Well to be fair, Olin. (S)He did tell us the markings on the components. Picture quality can be improved, I agree. It is rather... insane (if that's the correct word) to be expect us interpret a blurry picture. \$\endgroup\$ – KingDuken Apr 15 '18 at 16:40
The black one is a resistor packs.
I am not 100% sure how to interpret the code, but I guess the T8-2-472G is T8 for 8 pins, 2 for 4 independent resistors, 472 for 4700 Ohm (47 followed by two 0's). No clue wahat G is.
No idea what the other one is, it might be a resistor pack with a weird coding.
Voltage divider resistor SIP packs (single inline package)
A T8 should be a double Terminated where the number of paired terminations is the number of pins minus 2 common pins on each end similar to Bourns parts http://www.bourns.com/data/global/pdfs/dualterm.pdf
R values are given by the 3 digits with exponent.
G is a tolerance, as I recall F is 1% with no suffix being looser.
These are known to perform better where ratios matter for gain or offset stability with better matched ratios than discrete 1% parts inspite of absolute tolerances may be 1~10% . Some can be laser trimmed.
RED Resistor network 4610X-101-332LF Bourns enter image description here
    \$\begingroup\$ Thank you very much, that will help me a lot and makes perfectly sense. You don't have an idea what the red one is, have you? \$\endgroup\$ – low_k0 Apr 15 '18 at 15:38
