I have commonly seen the \$i^2t\$ rating for fusing in a SCR datasheet. This is a helpful rating for assessing if pulses which exceed the surge current rating (Itsm) of the SCR will damage it.
However, I have also come across the \$i^2\sqrt{t}\$ rating. These are commonly found in Vishay datasheets. The \$i^2\sqrt{t}\$ rating in the datasheets is constant for pulse widths ranging from 0.1ms to 10ms. I am guessing that the \$\sqrt{t}\$ is the thermal response of the SCR junction.
Has anyone come across this rating before and is there any literature that explains this rating? Google is giving me a hard time.
My application is a pulse width of 100-200us at an interval of 1.0s. I am trying to justify if I can use a SCR where I exceed the Itsm rating.
Sample Vishay Datasheet = http://www.vishay.com/docs/94679/vs-25tts16spbf.pdf
  • \$\begingroup\$ How about a link to a DS that specifies root(t) \$\endgroup\$ – Andy aka Apr 16 '18 at 10:40
  • \$\begingroup\$ Updated with datasheet link. \$\endgroup\$ – Oneneo Apr 16 '18 at 21:19
The \$i^2 t\$ is associated with the devices energy capability.
The maximum non-repetitive on-state surge current is generally quoted for one 10 millisecond sinusoidal. Such non-recurrent ratings are usually specified to allow fuse and circuit breaker short-circuit protection. The I2t rating for a 10ms period is another parameter used for fuse protection, where I is non-repetitive rms current.
However... This is only part of the story. When employed in a crowbar circuit, especially with a local DClink capacitor that will equally be rapidly discharged via the SCR, the energy capability of the SCR is closer to \$i^2 \sqrt t\$
The mathematical derivation of \$i^2 \sqrt t\$ can be seen in this SCR application notes.
https://edisciplinas.usp.br/pluginfile.php/2587503/mod_resource/content/2/Onsemi_Thyristor_Theory_and_Design_Considerations_Handbook_HBD855-D.pdf
Above the rated DC current the pulse duration is limited by the dissipation capability of the device. $$ \int{i(t)^2\mathrm{d}t}<\mathrm{[I^2t]} $$ For small pulse durations the thermal response of the junction limits the pulse current rating:
It has been shown that the dissipation capability of a device varies as to the \$\sqrt{t}\$ for the first tens of milliseconds of the thermal response and, in effect, the measure of a device’s energy capability would be closer to \$i^2\sqrt{t}\$.
ON Semiconductor, 2006: Thyristor Theory and Design Considerations
Here the math for arbitrary current pulse waveforms is not quite straightforward. $$ i(t)\sqrt{\smallint{i(t)^2\mathrm{d}t}}<\mathrm{[I^2\sqrt{t}]} $$ I tried to summarize the pulse current rating for the VS-25TTS16SPbF thyristor with the values from its datasheet: VS-25TTS16SPbF Pulse Current Rating For your application with repeating pulses you need to additionally ensure that your RMS current is within the specifications.
