I am trying the code in this datasheet on an Arduino mega2560 with mpu6050 IMU,
I have made some changes in the variables and I do not get errors so far. and the code doesn't give any output, can some show me a place with wrong code work?
I get mpu6050 range accX and accY -2^15 to + 2^15. I do not post code for mpu6050 since it works. I need to serial print and see how it displacement changes in this code. in positionxy() function I wanted to print
 Sample_X =  (unsigned char)accX/129;
 Sample_Y =  (unsigned char)accY/129;
 Serial.print ( Sample_X );  Serial.print ("\t");
 Serial.println ( Sample_Y ); Serial.print ("\t");
and it gives nothing, i think the issue is with the variable types and i cannot figure it out. The part of the code as follows,
//all varibles
double accX, accY, accZ;
unsigned char  Sample_X;
unsigned char  Sample_Y;
unsigned char  Sample_Z;
unsigned char  Sensor_Data[8];
unsigned char  countx,county ;
signed int  accelerationx[2], accelerationy[2];
signed long  velocityx[2], velocityy[2];
signed long  positionX[2];
signed long  positionY[2];
signed long  positionZ[2];
unsigned char  directionxy;
unsigned long  sstatex,sstatey;
void setup(){
 *****mpu 6050 config is done here and works aacX and accY updates with
 current accelration value  *****
void loop(){
do{
Calibrate();
movement_end_check();
positionxy();
}while(1);
void Calibrate()
************see datasheet **********
void positionxy()
unsigned char count2 ;
count2=0;
do{
Sample_X =  (unsigned char)accX/129; // this line is changed
Sample_Y =  (unsigned char)accY/129; // this line is changed
below serial print always gives zero
accelerationx[1]=accelerationx[1] + Sample_X;
accelerationy[1]=accelerationy[1] + Sample_Y;
movement_end_check(){
    \$\begingroup\$ Try printing accX and accY instead of the divided value. \$\endgroup\$ – Russell Borogove Apr 16 '18 at 18:19
  • \$\begingroup\$ @Russell Borogove Still same issue, I divided it since unsigned char can hold only 0-255, and I get -2^15 to +2^15 for the accX and accY \$\endgroup\$ – oppo Apr 16 '18 at 18:38
The conversion to unsigned char has precedence over division. So it first converts then divides afterwards. Use parantheses to override:
Sample_X = (unsigned char)(accX/129)
  • \$\begingroup\$ Sample_X gets the value update, but it does not change the value of acceleration, get same value all the time ant suggestions? i used Serial.print ( (int8_t) accelerationx ); Serial.print ("\t"); Serial.println ( (int8_t) accelerationy ); Serial.print ("\t"); \$\endgroup\$ – oppo Apr 16 '18 at 19:54
