I have come across the following half bridge rectifier circuit connected across phase R and T.
I'm wondering about the large resistor network in parallel with the source. What is the point of this and is there any benefits to it?
Thanks.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI have come across the following half bridge rectifier circuit connected across phase R and T.
Thanks.
The resistors are there to cut the inductive spikes when D022 and D023 are reverse biased. The parallel-serial is to minimize the effect of a failing resistor and also to split the voltage across resistors with lower voltage rating.
The overall resistance is Rt = 680k * 10 / 2 = 3.4M
Voltage per resistor Vr = 0.1 *V
In case of a failing resistor
Rt =680k + 680k * 9 / 2 = 3.7M
Voltage over the remaining resistor
Vr = V * 680 / 3700 = 0.18 * V
