I am trying to teach myself electronics, namely audio filtering, and I came across this circuit. Now with my limited knowledge the 'volume potentiometer' (that's what it is explained as) seems to be in parallel with the resistor forming the high-pass RC filter so would this mean that this circuit is wrong. I think that the output of each filter needs to be buffered and that those outputs should have the poteniometers on them? All the pots in the circuit are 10K Log's Audio Filter Circuit
It's not the best example of a three way splitter (I doubt you'll see something like this inpractice, it's just an example), but 680 is less than 10k, which means the cutoff will be little influenced. The same for the others where the cap is in parallel with the pot -- at cutoff, the impedance is less than the pot (~1.6k). That's not to say they will not be influenced, here's how the three outputs look like when there's no potentiometer (R=1G Ohm), compared to 10k:
test
Given @user7286370's comment: No, they combine, but as you can see in the picture, the effect of one large resistor in parallel with a small one will result in a new resistor that's slightly less than the smallest of the two. Consider the formula: \$\frac{R_1 R_2}{R_1+R_2}\$. If \$R_1\$ is much greater than \$R_2\$, what happens? Here's what happens when you put a \$10\Omega\$ resistor in parallel with another varying from 1 to 100:
plot
If the resistor is less than 10 (see the graph), the combined resistance drops significantly. If they are equal, 10 each, the resultant is 5, and as the resistor goes to 100 you can see the resultant value going up, towards 10, asymptotically. That means that, the higher the parallel resistor, the less impact it has.
Here's the equivalent schematic for the highpass case:
pot
As you can see, the pot effectively becomes two series resistors, with their values set by the wiper position (here, from 0 to 1). At the output you have the input impedance to the next stage (considered larger). From R1's perspective, it "sees" the two series resistances, thus the whole potentiometer, which, as determined above, does not influence too much R1's value. And, at the output, you have R2 with R3 forming a variable voltage divider.
Not sure what you meant to say with this: "does not act as a 'volume' control for a fixed value filter", but buffering is the recommended way to do it because, as you can see in the 1st picture, despite the large value of the pot, it still influences the filter, even if only by a bit.
|improve this answer|||||
  • \$\begingroup\$ Thank you but maybe I am a little stupid, are you saying that two resistors in parallel do not form a single resistor electrically but act as two seperate entities due to the differing values? \$\endgroup\$ – user7286370 Apr 17 '18 at 12:30
  • \$\begingroup\$ To be more precise, the encircled area in your picture shows a 680 and a 10k resistor, the resultant is (10k*680)/(10k+680)=636.7, which is less than 680, but not by much. Something of a rule of thumb says that if the parallel resistor is 10x greater or more, it is considered larger, if it's 100x or more, it's much larger. Note: don't take "rules of thumb" as laws, never; they are for guidance, only. \$\endgroup\$ – a concerned citizen Apr 17 '18 at 12:43
  • \$\begingroup\$ Thanks, so my assumption of the circuit being wrong is correct in that the pot becomes part of a network with existing resistors and does not act as a 'volume' control for a fixed value filter. Would I also be correct in assuming that each filter needs to be buffered with an opamp before passing to pots for mixing so that the amplitudes of high and low filters could be controlled independently? Of course however I understand that I could just leave them where they are to effectively adjust the cutoffs, but amplitude adjustment of fixed filters is the goal \$\endgroup\$ – user7286370 Apr 17 '18 at 13:02
I think this question has been well answered already, however I want to add a few things.
First the actual question: why are there potentiometers placed in parallel with other components (specifically resistors where it will change the resistance as they combine)?
The circuit will be designed with the pots to form the correct cutoff frequencies when they combine with the fixed resistors. The cutoff frequencies won't move depending on the position of the wiper as the resistance with respect to ground is constant. EDIT: as noted in comments this is only true individually! The interactions are negative. See my last paragraph re: interactions.
Effectively the circuit just gives a low-pass filter, band-pass filter, and high-pass filter and allows you to blend them together.
With regards to buffering: sufficient buffering would be provided by simply adding a summing amplifier at the output node of the given circuit. This would prevent loading of the filters.
Further if you're interested in this kind of circuit, there are lots of interesting tone stacks from both old and modern guitar amplifiers, check out this website. They were designed with minimal cost and with older technology. Putting an op-amp buffer everywhere wasn't really possible, particularly before transistors were even being used! The sound of the circuit was designed such that the interaction between sub-circuits would yield sonically pleasing results.
  • \$\begingroup\$ "The cutoff frequencies won't move depending on the position of the wiper as the resistance with respect to ground is constant." - They will move because all the pot wipers are connected together, so each pot affects the resistance to ground of the adjacent filters. If one pot is set to minimum it will short the other wipers to ground and there will be no output at any frequency. Bad circuit! \$\endgroup\$ – Bruce Abbott Apr 17 '18 at 14:14
  • \$\begingroup\$ Ah good point! I suppose I should have clarified they won't change the cutoff individually. \$\endgroup\$ – loudnoises Apr 17 '18 at 14:21
