I am trying to measure voltage across a 0.1R shunt resistor. When i measure voltage between input1 and input2 with multimeter i can see 10 mili volts. When i connect input1 to a voltage follower in the picture, op-amp starts to oscillate.
input1 and input2 are connected to voltage follower and after voltage follower i measure voltage across two outputs with differential amplifier.
I thought that this happens because of noise in input and added ~1hz lowpass filter to reduce noise but op-amp still oscillates.
I also added 1k resistor to output but no success. Op-amp i am using is TLC271CP which supports single supply operations.
Can you please help me how can i solve oscillation problem in voltage follower?
