Is it correct to have a path between the two pads. The width of the path is 8mil
  • 5
    \$\begingroup\$ It's a way. Whether it is correct or not depends on whether it meets your design rules. \$\endgroup\$ – Tom Carpenter Apr 17 '18 at 16:54
  • \$\begingroup\$ You also had to check the limits of the PCB manufacturer. 8mil traces are still standard, though. \$\endgroup\$ – Janka Apr 17 '18 at 17:00
    \$\begingroup\$ Those are the power pins for the TL084 (VCC+/VCC-). Such thin power traces with no bypass caps in sight feels wrong. \$\endgroup\$ – Unimportant Apr 17 '18 at 17:06
  • \$\begingroup\$ Thank you very much for the comments. This picture is only for the illustration purposes and I will not use it for the power ones. I just wonder if it is generally OK, taking into consideration all the circumstances (like current, voltage etc). \$\endgroup\$ – P__J__ Apr 17 '18 at 17:12
  • \$\begingroup\$ Two traces between those pads is possible for some PCB manufacturers. \$\endgroup\$ – Spehro Pefhany Apr 17 '18 at 17:32
9
If the width/thickness of the track can carry the current
AND
The clearance between track and pad can withstand the voltage difference
AND
Neither track or pads are sensitive analogue nodes
THEN
It's probably OK
