I am designing a wireless power Transmitter circuit and mostly following this datasheet for Wireless transmitter IC :- http://rohmfs.rohm.com/en/products/databook/datasheet/ic/power/switching_regulator_system/bd57020mwv-e.pdf
In the BOM table on Page 28-29, there are several capacitors and resistors which are shown in the Application Example Circuit but in BOM, there are marked as "OPEN" So i was wondering that if this "OPEN" means same as DO NOT MOUNT. Also the resistor and a common mode choke are marked as "SHORT". Are they shorted? Example:-
Capacitor CCLMP and Resistor RCLMP "open" CAP CCLMP and RES RCLMP
Similarly, ROSC as short and COSC1 COSC2 as open ROSC and COSC1 COSC2
The fact the data sheet offers no values next to these components should give you a clue that OPEN does indeed mean not fitted, otherwise what would you fit.
For me personally it would then follow that the SHORT does mean short too.
| improve this answer | |
