In a power electronics device, it seems that silicon carbide (SiC) has a higher variation of electrical on-state resistance with temperature in comparison to silicon (Si). Does anybody know the reason? I googled it, but I did find nothing in this case.
Here is a link that helped me (Page 2 of 6 shows good comparisons): https://www.fairchildsemi.co.jp/Assets/zSystem/documents-archive/collateral/technicalArticle/Overview-of-Silicon-Carbide-Power-Devices.pdf
To summarize:
  • Higher band-gap energy variance
  • Lower magnetic reluctance
  • Higher thermal condcutivity
  • Higher hole and electron mobility (more scattering is possible, meaning more variance)
  • \$\begingroup\$ Thank you for your comment, in the link, it is mentioned: The ON-resistance of the SiC MOSFET increases by about 20 percent when the junction temperature increases from 25°C to 135°C, whereas that of the Si MOSFET increases by 250 percent...... While in datasheets you can find a contrary conclusion. \$\endgroup\$ – Mohsen AB Apr 30 '18 at 22:41
  • \$\begingroup\$ Of course, I am talking about Si IGBTs and SiC MOSFETs. \$\endgroup\$ – Mohsen AB Apr 30 '18 at 23:08
