I design a simple PCI-E riser. I need a clue, I'm stuck on a relatively simple element. I would like to connect two power supply lines + 12V (pads B1 and B2) on the top layer and then go through the three passes to the Bottom layer. In addition I wonder how to get the irregular shape of the path visible on the right in the selected rectangle (red color). Shoud I use Polygon Plane?
Thanks for your support! I did the following:
- created Polygon Pour, connect it to Net +12V
- selected Pour Over All Same Net Objects
- selected Layer: Top Layer
Next I've set proterties of Viases: Net -> +12V.
Is this correct?
I will also use the Interactive Length Tuning function, thank you for the link!
