I am working on a project for my physics class to test the resistance of various flames.
This will involve using a spark gap with high voltage and I am in the process of building a small Faraday Cage to protect the people outside from any sparks that are a higher voltage than expected, also just to keep them from having the urge to touch it. (The logic being that people are a lot more respectful of radioactive sources when there's a Geiger counter clicking away in the background.)
The problem is this: I need to earth the cage so that the cage itself doesn't become charged but I'm on the 7th floor and its not using a mains power source and I'm not sure what I could use as an earth.
I had thought of earthing it to a radiator pipe, since they're grounded anyway, but I'd be worried about maybe building up charge there that passes through somebody on a higher floor or something and most other ideas I had, had similar problems.
I had also thought about connecting it to the ground of the spark generator assembly, which is not connected to the earth, but I have some strange gut instinct telling me that would be damaging to something or stop the cage working as intended.
Its very important the safety precautions I take are as good as possible because my lecturer is liable for my safety and I don't want to make any mistakes that could hurt somebody due to my ignorance.
I have done some research on grounding and Faraday Cages but I can't seem to find anything other than "Warm, wet dirt is better than cold, dry dirt" and I don't think carrying a bucket of warm moist soil up to class would be appreciated, enjoyable to do, or even work that well as a ground because I can't find anything on exactly how much soil is needed to qualify it as a good earth.
NOTES: There are earthed outlets. I am from Britain if that's important. I wasn't sure if I could just remove the live and earth cables from the plug and use it solely for its ground pin as I am more familiar with electronics than building wiring.
The cage will be approx. 42x30x23 cm
The cage is totally bare steel wire, not painted.
The frequency of the AC spark is approximately 70Hz with a rise time of approx. 50us
This assembly and the experiment will be on an insulated base raised from the table by bricks.
The length of arc will be approx 3cm but it will be passing mostly through the flame, not air.
The voltage will be on the order of 3kV and I cannot tell you what the current limit of the source will be until I can have a look at the specs for the source, which is approx 30 miles away right now.
Thanks for reading.
