STM32F2: Makefile, linker script and start-up file combination without commercial IDE is a simple but brilliant explanation of what happens when we start a system based on a Cortex-M series processor.
Will be grateful if a similar simple information is provided for Cortex-A series processors too. Since Cortex-A processors use MMU, and conventional embedded-linuxes run ONLY on Cortex-A, so I am presuming that the bootup process would be significantly different.
Thanks in advance.
Thanks and Regards, Ajay
  • \$\begingroup\$ Well, the embedded Linux source code is available, so you could read that. \$\endgroup\$ – Brian Drummond Apr 20 '18 at 6:40
  • \$\begingroup\$ The biggest difference is if you have multiple cores. You need to start one and leave the others initially idle. The MMU is off after booting. \$\endgroup\$ – Oldfart Apr 20 '18 at 7:02
  • \$\begingroup\$ Cortex-A chips vary a lot. i.MX6 has a ROM that tries to load the bootloader from SD card, NOR flash, USB etc. You could perhaps study the boot process of Raspberry Pi. \$\endgroup\$ – filo Apr 20 '18 at 7:09
  • \$\begingroup\$ @filo Pi is a bad example since the official bootloader is closed source \$\endgroup\$ – Jan Dorniak Apr 20 '18 at 8:01
  • \$\begingroup\$ @filo, we say that ROM tries to load the bootloader from SD card, NOR flash, USB etc. Does this mean that the ROM-code is burnt just once into the ROM, and if there is absolutely nothing on the board, then the CPU will simply keep waiting for a bootloader, by looping onto the (one-time burnt, fixed) code present in ROM? \$\endgroup\$ – Ajay Garg Apr 21 '18 at 5:42
The provess varies a lot depending on a particular SoC, but the general sequence is:
  1. Load bootloader (this depends on SoC)
  2. Bootloader initializes the most important parts - crystal, RAM, other stuff (and possibly allows changing the kernel)
  3. Bootloader runs the kernel
The most common open source bootloaders are U-Boot and RedBoot. If you want a hobbyist board to play around with I suggest Beaglebone - that SoC has very good open documentation and the relative U-Boot parts were contributed directly by TI.
  • \$\begingroup\$ Thanks Jan for the help. As per point 2, boot-loader initializes the RAM. (May be that is the reason why global-data-structure gd in uboot is declared with register storage-class, please confirm). Now, youtube.com/watch?v=3brOzLJmeek says that there are internal-ram and external-ram. Firstly, what is the difference between the two? Secondly, boot-loader initializes internal-ram or external-ram or both? \$\endgroup\$ – Ajay Garg Apr 21 '18 at 6:22
  • \$\begingroup\$ Internal RAM is otherwise listed as cache memory and it does not need initialization. \$\endgroup\$ – Jan Dorniak Apr 21 '18 at 9:54
  • \$\begingroup\$ @AjayGarg if my answer helped you consider upvoting or accepting it \$\endgroup\$ – Jan Dorniak Apr 21 '18 at 11:51
