My whole house is setup with Wi-Fi wall switches. They're just like basic 110V wall switches, but they can be controlled via Wi-Fi. I'm in the U.S. I'd now like to enable my fireplace. The fireplace runs today from a standard wall switch, it's not a millivolt switch. The switch turned on releases the gas, lights the pilot, and then turns the gas on full via 3V DC.
So, I'm in a place where I need to control extremely low voltage DC with 110V AC. I thought about an SSR, but AC-DC relays don't seem to exist. I thought maybe an A.C. SSR-25AA that I had laying around would complete the millivolt circuit, but resistance doesn't seem to change with the SSR. Would it on an electromechanicsl relay? I then thought about transforming the AC to DC, but I was hoping for something smaller with fewer components. While testing, I found that when I switched from 1K to 10 ohms, the multimeter's resistance turned on the fire. Switching back up turned it off. Maybe a resistor on my SSR would work?
What is the best way that I could switch low voltage DC with house AC? Can AC being on just complete a simple DC circuit somehow?
Thanks.
