-1
My project is based on a strict time management and precise event timing
for that I need to vary the PWM frequency and duty cycle in real time with two potentiometres.
I've succeded to vary the duty cycle with one potentiometre using a pic18f2550 but I couldn't neither add another analog input for the second potentiometre nor vary the frequency.
I also may need up to 4 PWM signals which will be identical but delayed between eitch other, for this I know that the 18f family has only two CCP modules, so could you please tell me which pic can do the job.
the code below is for a simple duty cycle variation.
Any help is strongly appreciated
thank you all in advance
#include <xc.h>
#include "PWM_config.h"
#include <pic18f2550.h>
void init_ADC (void)
ADCON1=0b00001110; //setting voltage reference and AN0 as analog input
ADCON0bits.CHS=0b0000; //setting channel 0
ADCON2=0b10011101; /* 16Tosc conversion clock, 6Tad acquisition time, ADC Result Right Justified */
int doADC0(void)
int result;
ADCON0bits.ADON=1; //turning on ADC
__delay_us (5); // acquisition delay of 4.6 us
ADCON0bits.GODONE=1; //start conversion
while (ADCON0bits.GODONE==1);
result=ADRES*0.0977517;
return result;
void init_PWM1 (unsigned char period)
TRISCbits.RC2=0;
/*CCP PWM mode*/
CCP1CONbits.CCP1M=0b1100; //CCP1 to PWM mode
CCP1CONbits.DC1B=0b00;
/*timer2 configuration*/
PR2=(period*312500)-1; //avec Fosc=20MHz
T2CON=0x02; //set prescaler to 16
TMR2ON=1;
void PWM_setDC (unsigned int pourcentage_DC)
unsigned int DC=(10.23*pourcentage_DC);
CCPR1L = DC>>2; // PWM duty cycle - first 8-bits (MSb)
CCP1CON |= ((DC<<4)&0x30); // PWM duty cycle - last 2-bits (LSb) in CCP1CON 5,4 bits
void main (void)
TRISAbits.RA0=1;
init_ADC();
init_PWM1(0.002); //setting the period to 2ms
while (1)
if (doADC0()<1) {PWM_setDC(0); PORTCbits.RC2=0; }
else PWM_setDC(doADC0());
  • \$\begingroup\$ I have to say the formatting is awful. \$\endgroup\$ – a concerned citizen Apr 20 '18 at 10:56
I would start with a 16f1788 pic, has 4 programmable switch mode controllers and PSMC GUI tool available from Microchip. It saved me hours of programming and debugging. The tool makes pwm configuration very easy.
  • \$\begingroup\$ The problem is that this configuration is fixed for the hole program. But for my case I need an instant variation of the frequency. \$\endgroup\$ – Gon Freeks Apr 20 '18 at 13:18
  • \$\begingroup\$ what would be the range of frequency you look for ? \$\endgroup\$ – johnger Apr 20 '18 at 13:54
  • \$\begingroup\$ from 10Hz to 100Hz \$\endgroup\$ – Gon Freeks Apr 20 '18 at 15:18
