How can I change the frequency of a simple RF transmitter?
These are the transmitters in question:
Background Research
On this question s3c
says:
To change the transmit frequency you'll have to change the SAW resonator as well as some component values
I have a SAW oscillator for 304.25MHz
, the frequency I'd like to broadcast at.
I noticed in the photo above that the inductor coil has a different number of turns for the 315MHz and 433MHz transmitters.
A page describing a similar FM transmitter says:
The transmitter can be modified to any frequency between 50 and 400 MHz by replacing ... the inductor which is an oscillator coil and a capacitor
Additionally there is a schematic for the circuit on electroschematics.com:
That schematic is for the 433MHz circuit and it uses two 47k resistors, and this blog shows a closeup of a the back of a 433MHz module using two 27k resistors instead:
It also offers a hand drawn schematic:
I believe this is a photo of the back of a 315MHz transmitter and it appears to use resistor values of 20k and 27k:
How can I modify the frequency of one of these transmitter modules?
- I believe I need to switch out the SAW oscillator
- I think I need to change the number of turns in one of the inductor coils
- I may need to change the values of the resistors
- Wavelength can be calculated using the formula at the bottom of the hand-drawn schematic - so a quarter length antennae for would be 17.3cm for 433MHz, 23.8cm for 31Hz, and 24.6cm for 304.25MHz
- Not sure how I might calculate the values for these components.
- Not sure how to test - maybe using a USB RTL-SDR tuner?
