I have In-wheel BLDC motor having 46 poles (Permanent Magnet)on rotor and 51 slot in stator. When I used an external machine to rotate my in-wheel BLDC motor, then measuring across two phase back emf I got sinusoidal back emf instead of trapezoidal. Can any one explain why this happened? enter image description here
For the measurement of Back emf constant, how one can calculate if back emf is sinusoidal ?
You are measuring the line-line voltage and not the phase voltage.
The characteristic "trapezoidal" backEMF is only present at the phase voltage. When you view this line-line the waveform appears like a pointy sinewave. Then there are specifics of the build: magnet span, width of stator tooth foot... all these things influence the shape of the backEMF. With a high polecount the arc needed for a magnetic gap will be very small and probably non-existent.
And thus the line-line at the terminals would appear:
in practice you won't see this and it will naturally be rounder as this is the mathematical concise result. The point still stands. Line-Line is more sinus than most appreciate.
  • \$\begingroup\$ In this situation how one can find Back EMF constant? \$\endgroup\$ – aman2909 Apr 21 '18 at 10:14
