I'm studying a circuit with BJT's and I'm asked to determine the input resistances of the two amplification steps of the circuit. The circuit I'm analyzing is the following one:
To determine the input resistances I performed an AC analysis and obtained the following results:
I know that the values are not perceptible but they are Rin1=23.272231 kohm and Rin2=220.77106 kohm. I decided to choose a somewhat random value in the zone of the graphic where the curves are constant (I'm not sure if this is correct...).
Well this value are very different from what I obtained when I analyze the theoretical values of the input resistances.
Using:
$$R_{i2}=(β+1) R_{E3}//R_L+r_{π2}$$
where r_{π2} is 9.375 kohm and beta is 300. I obtained R_i2=240.375 kΩ
And for Ri1
$$R_{i1}=R_1//R_2//(r_π1+R_{E1} (1+β))$$ I obtained R_i1=20.183kohm.
I used the small-signal analysis models to determine this...
Now this is odd. I'm getting an error of about 15% on Ri1 and 7% on Ri2. Am I doing something wrong or are this deviations perfectly normal and dependent on the methods used on the theoretical analysis and on LTSpice. Can someone help me clarify this?
  • \$\begingroup\$ Your uploaded picture needs re-saving and re-uploading. Have you used the transistors, separately, to determine their values? Models usually differ from real life. Also, you could try to use a current source at the input, and plot 1/V(vs), but I suspect it will be the same. \$\endgroup\$ – a concerned citizen Apr 22 '18 at 6:42
  • \$\begingroup\$ How do you determine the r_pi value? Also, LTspice includes ro resistance and VT at 27 degrees, \$\endgroup\$ – G36 Apr 22 '18 at 8:53
How does the SPICE model differ from hybrid-pi? Are those differences important?
  • \$\begingroup\$ Beta is slightly different (294.3 versus 300). Also the values of r_pi might be a little bit different, because the currents are slightly different than 0.8 mA. Will that be enough reason? \$\endgroup\$ – Granger Obliviate Apr 22 '18 at 2:44
At \$1 \textrm{kHz}\$ the \$C_E\$ capacitor reactance is around :
\$X_C \approx \frac{0.16}{F \cdot C}\approx 1.6\textrm{k}\Omega\$
So the \$Z_E\$ impedance will be around:
\$Z_E = R_{E1} + R_{E2}||X_{C_E} \approx 1.2 \textrm{k}\Omega \$
And input impedance is:
\$R_{in1} = R_1||R_2||(Z_E + r_e)(\beta+1) \approx 23.232 \textrm{k}\Omega\$
Rin1 = 1/( 1/68 + 1/39+1/((1.2+0.0325)*301))
I assume \$I_C = 0.8 \textrm{mA}\$ and \$r_e = \frac {26\textrm{mV}}{I_C} = 32.5\Omega\$
As for \$R_{in2}\$ is equal around:
\$ R_{in2} = (R_{E3}||R_L||r_o)(\beta+1)+r_{\pi2}\$
Because the LTspice includes \$r_o\$ (Early effect).
So to get almost exactly the same result you need to know \$ro\$ or Early voltage \$ \textrm{VAF}\$ in LTspice.
