I apologize if my question sounds stupid, but I'm a novice and trying to explore all of my options. I currently have a 4/16 decoder, but I did not realize it was active-low and what I really need is an active-high decoder. How might I go about fixing this without putting an inverter on every output? Thanks!
(datasheet: https://datasheet.octopart.com/NTE74HC154-NTE-Electronics-datasheet-22129262.pdf)
  • \$\begingroup\$ I'm considering just buying a 16-gate inverter if that exists \$\endgroup\$ Apr 22, 2018 at 13:31
    \$\begingroup\$ @BrianDrummond I was in a bit of a rush and this was the only decoder available, so I didn't check the datasheet when I got it (should have). Downstream is just some leds with a pull-down resistor, so I can't think of a way to modify this to also be active low. Any ideas? (Might just go with 7404s) \$\endgroup\$ Apr 22, 2018 at 13:51
    \$\begingroup\$ Is that all? Run the LEDs with pull UP resistors to +V. That's how it was always done in the TTL (good at pulling low) days. \$\endgroup\$
    – user16324
    Apr 22, 2018 at 13:52
    \$\begingroup\$ @BrianDrummond Would that look something like this? (4/16 decoder output pin)------(resistor to V+)-------(led) \$\endgroup\$ Apr 22, 2018 at 14:02
    \$\begingroup\$ @CalebWhittington yes, although it's more traditional to put the resistor on the VCC side of the LED. \$\endgroup\$
    – Alnitak
    Jun 15, 2018 at 15:56
Just invert the logic of the downstream circuitry.
To drive a LED, do this:
(BUF1 is just any of your decoder's output pins) The resistor and LED can be interchanged.
That's the way TTL circuitry (good at pulling low) was always used.
