I'm trying to implement the Schmitt trigger found in "CMOS" by J. Baker. Here's what the circuit should look like:
And this is how the transistors should be dimensioned to achieve switching voltages of 0.7V and 0.4V:
And here's what the output should look like:
This is what my circuit and simulation results look like:
As you can see, my Schmitt trigger doesn't switch at the correct voltages and the output is all lumpy.
In terms of troubleshooting, I have double-checked the connections and transistor dimensions. Also, I played around with the voltage source Vdc to see if I needed a larger voltage. Adjusting the voltage higher than 1Vdc breaks the circuit entirely.
Where have I gone wrong?
I found this SCHMIDTT much more controllable
  • \$\begingroup\$ how do I dimension the transistors? with the same equations in my original post? \$\endgroup\$
    – suhh_drude
    Apr 25, 2018 at 14:08
