I'm working on some acceleration data, looking at vibrations and at what frequencies they're occuring. The recorded periods are fairly long (~1 minute) and I was wondering, what's the difference was between doing a FFT on the whole 1 minute data set and taking the magnitudes, vs doing fourier transforms for each second, taking the magnitudes, and then averaging them at the end?
  • \$\begingroup\$ This question might get better answers (or already have been asked and answered) on Signal Processing. \$\endgroup\$ – The Photon Apr 24 '18 at 2:45
This is the basics of spectral analysis using digital Fourier transform. Mountains of literature is written on the subject.
In short, when you do a FFT over the entire data set 1-minute long, you will have fairly high spectral resolution of about 1/60 Hz, or 16.6 mHz (milliHz). But your confidence interval of the amplitude at each frequency line will be very low, you will have a very high ~100% noise level.
When you break your data into smaller blocks, so for each second-long data your spectral resolution will be 1 Hz, low. But, if you take an average of all 60 periodograms, your noise level will be SQRT(60) =~8 times smaller, so you can be much more confident if you see some spectral peaks in your spectrum.
Note, that this works only on power spectrum estimates, Re^2 + Im^2.
So, with a limited data set, there is a trade-off between accuracy of estimates of spectral amplitudes, and frequency resolution of your power spectrum.
