Hello!
I'm currently stuck trying to answer this question. The question asks for me to find the resistance of R2 for R1 to be at 4V when the PNP transistor has a beta of 250. My current train of thought was to substitute 4V as the voltage of R1 and solve for current which gave me 80mA, then use Ic = β/Ib to calculate Ib which was 0.32mA. I also worked the emitter current, Ie to be approximately 79mA.
This is where I got stuck, I now know the current of R2 but I don't know the voltage or the resistance so I can't work out either of these values. Is there something I'm not considering here? Am I going about this the wrong way? I'm really confused. Any help would be appreciated!
    \$\begingroup\$ Was the VBE given to you? If not, are you told the saturation current for the BJT? \$\endgroup\$ – jonk Apr 24 '18 at 23:22
The voltage across R2 is going to be 6- Vbe if your transistor is working in linear region, where Vbe=~ 0.6v is the PN junction voltage to be overcome in order to make the transistor work.
So the voltage across R2 is VR2 = 6-0.6= 5.4V
With this value you can apply the formula R2 = VR2/Ib and you´ll find the resistor value.
  • \$\begingroup\$ If a given answer was helpful, you should give it an upvote accordingly :) \$\endgroup\$ – po.pe Apr 25 '18 at 6:17
