I am designing a PCB for a Numitron clock. It is just my own project, not for a company. The milling machine at school can only deal with 16mil+ sized traces, so I have some troubles routing traces between IC pins, for example. I must also note that I can only have 2 layer PCB's made at school. I have attempted to route the board several times now, but I always hit dead end, because something always crosses another trace. If I were to introduce vias, that would make things a lot easier, although the PCB would not look as nice, because I would have to connect it with wires externally.
My question is - are vias an acceptable solution, or is it a last resort? I imagine that in real life each via increases production cost, and that is a part of PCB design considerations, but what other pros and cons are there to vias?
    \$\begingroup\$ In real life the cost of each via is zero. \$\endgroup\$
    – user110971
    Apr 25, 2018 at 11:54
    \$\begingroup\$ "because I would have to connect it with wires externally" - What do you mean by this? Are you perhaps confusing vias with jumpers? \$\endgroup\$
    – Dampmaskin
    Apr 25, 2018 at 11:56
    \$\begingroup\$ Vias are internally connection between layers, not externally. \$\endgroup\$ Apr 25, 2018 at 11:57
    \$\begingroup\$ @Dampmaskin I am assuming as they're milling the board the 'via' would be a hole with annular ring on both sides and they would solder a wire in, rather than having through plating. \$\endgroup\$
    – Colin
    Apr 25, 2018 at 12:04
    \$\begingroup\$ Rather than vias you might try using "0 ohm resistors" or a bit of wire to help with routing a particularly complex part of the board. You can route many traces through the footprint of a standard through-hole resistor. \$\endgroup\$
    – scotty3785
    Apr 25, 2018 at 16:26
Vias are totally acceptable and used in almost any design, the most important things you have to worry about is the use of via's on high frequency lines and on power lines.
If you have a part which requires some higher currents or anything, say a design of a power supply for example, it is required you put several vias in the same line or in the same power polygon to be able to handle this current
Stack exchange current through via
The other problem with higher frequencies, is that if you have a multi-layer board the via can act as a stub, the stub can act as an unterminated transmission lines causing problems with your signal integrity.
More info about Stub and vias
To summarize: Vias won't increase production cost (unless you do special operations like blind vias or back drilled vias and are used in probably all two or more layer designs.
  • \$\begingroup\$ For milled boards, vias definitely increase production cost. \$\endgroup\$ Apr 25, 2018 at 12:29
  • \$\begingroup\$ Will multiple vias cause ground loop problems ? \$\endgroup\$ Apr 25, 2018 at 12:38
  • \$\begingroup\$ No ground loops are not in particular caused by via's, ground loops can occur if the the ground has a different potential on different places in your design. Thats why pcbs usually have one or multiple ground layers, and vias stitching all the grounds together at multiple locations on the board. A more likely problem can be a really lengthy or weird return path for the current which is mostly controlled by proper layouting and pcb design. \$\endgroup\$
    – Remco Vink
    Apr 25, 2018 at 12:56
  • \$\begingroup\$ @SimonRichter - Why? It's just a hole - there's no plating if the OP is referring to soldering a bit of wire through... \$\endgroup\$
    – brhans
    Apr 25, 2018 at 15:00
  • \$\begingroup\$ @brhans, "soldering a bit of wire through" is an extra step, and extra cost, compared to finding a way to design with no via. \$\endgroup\$
    – The Photon
    Apr 25, 2018 at 16:48
