I have a staircase generator circuit with a MOSFET connected to capacitor 2. The input of the capacitor is connected to a comparator and I wish for the MOSFET to cut off when the output of the comparator is high.
The comparator is connected to a sine wave generator.
The waveform I want to achieve is shown below:
I am having problems achieving this, when the MOSFET is disconnected as above, the wave form I get is this:
So the blue staircase wave is working as intended albeit not resetting. However, the moment I connect the MOSFET the staircase waveform is affected with some weird fluttering at the beginning and it is not resetting the staircase:
enter image description here.
I have confirmed that with a manual switch the staircase resets as needed, however, I cannot get the transistor to work as intended.
    \$\begingroup\$ This question looks extremely familiar... You didn't happen to delete this question and ask it again, did you? \$\endgroup\$
    – user103380
    Commented Apr 25, 2018 at 15:17
  • \$\begingroup\$ I deleted it yesterday because I realised I misunderstood the question, and what I was asking for was not possible or at more difficult than the scope of the question. Unfortunately only realised after wasting a lot of time. \$\endgroup\$ Commented Apr 25, 2018 at 16:20
It cannot work like that. The MOSFET discharges the capacitor just down to the value where VStaircase goes a bit lower than Vsine, not down to zero as you wish. It's a negative feedback, that it should do.
To act as you wish you need to trigger a short impulse that fully opens the MOSFET for a short time.
