I saw this sensors in an YouTube video where these things were glued to Glenn Maxwell's dress and his whole movement was monitored for the making of a cricket game.
    \$\begingroup\$ If I recall correctly, those aren't sensors, they're beacons for external sensors to track. \$\endgroup\$ – Hearth Apr 25 '18 at 22:59
  • \$\begingroup\$ they are just "dots" ... video camera and motion recognition software translate the dots to this gotoandplay.it/_articles/2007/04/skeletal_animation/… .... other software uses the resulting data to animate virtual actors \$\endgroup\$ – jsotola Apr 25 '18 at 23:08
  • \$\begingroup\$ Typically used for 3D animation for movies and video games. They're not sensors but rather "joints" that a computer can recognize and detect so that a model is able to mimic the movement. They then put the locations into some type of stick figure model and then whatever want over that stick figure model (i.e. a monster or some supernatural being). Saves a lot of money and time to animate 3D objects this way as opposed to frame by frame movements. \$\endgroup\$ – KingDuken Apr 25 '18 at 23:45
  • \$\begingroup\$ They are reflective IR balls that IR cameras can easily see, they have a few cameras and the position of each ball can be triangulated to a few mm \$\endgroup\$ – Voltage Spike Apr 26 '18 at 21:40
I don't think those are sensors. I think those balls, against a black background, are a constellation that can be dealt with efficiently using computer vision techniques from normal camera output. Algorithms that know something about how they are distributed on a moving body can infer the movement of that body through space mapped onto a 3-D model with hinges and joints. The technology as a whole is called "motion capture" I believe.
Maybe they are also highly reflective to IR or something, but I seriously doubt they are "active" in any way.
| improve this answer | |
