This Serial Communications Controller from Zilog lists a few of its pins with a bar above the name. What does this bar mean?
From a schematic I have been looking it seems a few of these are inactive when high and active when low?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityThis Serial Communications Controller from Zilog lists a few of its pins with a bar above the name. What does this bar mean?
As you surmise, it means that the function the pin name implies is active when low.
For example, /INT is low to trigger an interrupt and /WR is low to indicate a write.
It usually means an active low pin.
