I have a really big design to do and I'm having a rough time with buses. I have several doubts I hope someone can help me solve.
Can I take a bus between sheets using an Off-Sheet Connector? For example:
Altium Bus + Off-Sheet connector
Can I make a bus containing differential pairs? (And take it to another sheet using an Off-Sheet Connector) I have tons of differential pairs and I'd like to avoid using so many individuals Off-Sheet Connectors.
Thanks in advance!
You can use harnesses instead of busses to pass them between sheets in a hierarchical design:
Source: EEvblog
You will get compiler warnings which you can turn off if you so desire
  • \$\begingroup\$ That should solve my problem with differential pairs. What about buses and Off-Sheet connectors? \$\endgroup\$ – user1903 May 1 '18 at 18:36
  • \$\begingroup\$ The harness can use busses and connectors to pass between sheets in a hierarchical design. In theory harneses should be able to work with offsheet connectors as they simply define a bus, but I have not tested this. \$\endgroup\$ – Voltage Spike May 1 '18 at 19:56
  • \$\begingroup\$ I have tested the busses and it works, I never use off sheet connectors. \$\endgroup\$ – Voltage Spike May 3 '18 at 15:51
