We are working on a project to produce a simple walkie talkie repeater. We have a RTL SDR, which we are using to reverse engineer our signal. Using this + URH, we think our signal is PSK modulated, 305 bits per second. Here's a screenshot of our data: Received signal
For our actual project, we want to use a YARD Stick One to both transmit and receive. But the YARD Stick One only supports ASK, OOK, GFSK, 2-FSK, 4-FSK, MSK modulations. Since it isn't a real SDR, it seems we only have the option of binary data in, binary data out. Are we up a creek without a paddle here, or is there some workaround we can use?
In the worst case, we can get new hardware
For reference, here are links to the documentation we have for our walkie talkie, YARD Stick One, and RTL-SDR.
    \$\begingroup\$ What is the thick red line across the middle of your screenshot representing? What is "+ URH" \$\endgroup\$ – Andy aka Apr 27 '18 at 8:42
No.
None of the supported modulations is pure PSK; the closest you get is MSK, which, by mathematical happenstance, is like O-QPSK with a halfwave pulse shaping filter. But due to the offset nature, that's not really PSK at all, in general.
I'm taking a wild guess from your signal plot that this might be QPSK. That would give us a symbol rate of 152.5 bd. That's nearly incredibly slow. Are you sure? This isn't anywhere fast enough for speech transmission, so this is only about some control messages. Are you perhaps working with an FM handset (very likely, there might be regulatory rules that mandate it does FM) with something inside? Your signal plot is really not that enlightening, as it looks like it hides the information as the "small" oscillations modulated atop of the "large" oscillations by being zoomed out too far.
Under the condition that we're actually dealing with a receiver that has applies a filter of little more than 150 Hz bandwidth, the offset component duration in the yard-stick-synthesizable MSK might actually, with a healthy degree of luck that the pulse shape is OK for your receiver, be negligible, if you "just" used a large multiple of your needed symbol rate as the symbol rate of the yard stick, and repeated each symbol as often as that multiple dictates, so that there's no change of constellation point (or, conversely, just continuous wave in MSK) for most of the 1/152.5 s duration of a symbol, and just a tiny fraction between these low-rate symbols that looks a bit strange in how it changes from one phase to another.
Generally: wrong tool for the right job, I'd say. Maybe look into proper SDR frontends.
