Let's assume I have a static computer desktop on my external display that is attached by HDMI (or equivalently, it could be attached by DVI, as DVI and HDMI are compatible). The 60Hz picture doesn't change at all but stays static instead.
Is HDMI transferring the full picture 60 times per second digitally? Or is there some kind of buffer on the display device, so that HDMI transfers only the modifications to the picture?
Does the answer change when DisplayPort is used instead of HDMI/DVI?
