For personal hobby projects I'm using prototype boards like this (2.54 mm pitch):
I connect them using wires, which is a mess. I want to use a backplane with female edge connectors, for a solution like this:
Making a PCB is out of question, mostly because I keep adding components to my projects to add further functionalities.
After searching, the only female edge connector I found was 3.96mm pitch ones, that seems to be incompatible with prototype boards.
I'm looking for a solution, better if it accepts the prototype board as is (without a male connector). Cost is not a big factor.
Any sugestion is welcome.
Edit
Durability is not an issue; I keep producing new versions every 12 to 18 months. Cheap components, hardware is totally disposable (I don't even bother recycling them).
