The diagram below represents the position of ocean oil platform system which use the proportional controller with gain \$k\$. The output \$x(s)\$ is the platform deflection regards the position desired. Consider the platform initial position \$0\$ and it subjects of waves forces the sea, which effect could be represented for disturbance \$d(s)\$.
a) Determine the transfer function \$x(s)/d(s)\$ in terms of \$k\$ and \$G(s)\$.
b) Consider the Bode diagram below with respect of \$G(s)\$. Suppose that it apply a disturbance as unit step function (\$u(s) = 1/s\$). What the amplitude of deflection, in steady state, of platform in respect the position desired in function of gain \$k\$?
c) Consider now that the disturbance would be the sine signal on time domain given by expression \$d(t) = \sin(10t)\$. Determine the value of the gain from proportional controller \$(k)\$ for, in steady state, amplitude of deflection of platform in respect the position desired been equal to \$0.1\$
I really think that I've solved correctly the letter a) and b) but i have theory doubts about the letter c)
a) \$x(s) = -x(s)\cdot k \cdot G(s) + d(s)\Rightarrow \frac{x(s)}{d(s)}+\frac{x(s)\cdot k \cdot G(s)}{d(s)} = 1\$
\$\boxed{\frac{x(s)}{d(s)} = \frac{1}{1+k \cdot G(s)}}\$
b) We need to value \$x(t\rightarrow\infty)\$? but \$e(t\rightarrow\infty) = \underbrace{\text{input}(t\rightarrow\infty)}_{=0} - x(t\rightarrow\infty)\$
\$e(t\rightarrow\infty) = -x(t\rightarrow\infty)\$
\$E(s) = R(s) - x(s) = -x(s) = -d(s)\cdot\frac{1}{1+k \cdot G(s)} = -\frac{1}{s}.\frac{1}{1+k \cdot G(s)}\$
\$e(t\rightarrow\infty) =\lim_{s\to 0}s \cdot E(s) = \lim_{s\to 0}s\cdot-\frac{1}{s} \cdot \frac{1}{1+k \cdot G(s)} = -\frac{1}{1+k\cdot G(0)}\$
\$G(0)|_{db} = 6.25\$
\$ \boxed{x(t\to \infty) = \frac{1}{1+k \cdot 10^{\frac{6.25}{20}}}}\$
I stuck the letter c)
Consider \$\mathscr{L}(sin(10t)) = \frac{10}{s^2+10^2}\$
\$e(t\rightarrow\infty) = -x(t\rightarrow\infty)\$ (same idea that letter b)
\$E(s) = R(s) - x(s) = -x(s)\Rightarrow e(\to \infty) = \lim_{s\to 0}s.-d(s).\frac{1}{1+k\cdot G(s)} = \lim_{s\to 0}s\cdot-\frac{10}{s^2+10^2}.\frac{1}{1+k.G(s)} = 0\$
Seems something I've missed this part.
Can someone give me any hint?
  • \$\begingroup\$ It's steady state sine response, so use frequency domain rather than time domain. Let \$s\rightarrow j\omega\$ in the TF, then let \$\omega=10\: rad\:s^{-1}\$ to determine the gain at that frequency. \$\endgroup\$ – Chu Apr 30 '18 at 18:10
  • \$\begingroup\$ what do you mean? in \$w = 10rads^{-1}\$ the gain is \$|G(jw)| = 0db = 1\$ and \$TF = \frac{1}{1+k}\$ \$\endgroup\$ – miguel747 Apr 30 '18 at 19:05
    \$\begingroup\$ Yes, so that gives \$ \small k=9\$, if I'm reading the question properly. \$\endgroup\$ – Chu May 1 '18 at 0:10
  • \$\begingroup\$ For the Final Value Theorem to be valid: (1) All roots of the denominator of a F(s) must have negative real parts. (2) No more than one can be at the origin. Your "sine" function violates (1). \$\endgroup\$ – Dirceu Rodrigues Jr May 1 '18 at 15:32
  • \$\begingroup\$ @DirceuRodriguesJr thanks for the details about the Final Value Theorem. But regards the last tip for Chu, the value of x(t) on steady state must be \$ 10/(s+10^2) \cdot TF\$ instead just TF. But if I used the first expression to w=10 rad/s It would go wrong value again. Because the term of sine on frequency domain at the frequency will blow up the value. \$\endgroup\$ – miguel747 May 1 '18 at 15:45
I don't know if I am understanding your question correctly—the wording is a bit confusing.
You know that your output to disturbance ratio is defined by the transfer function:
$$\dfrac{x(s)}{d(s)}=\dfrac{1}{1+kG(s)} $$
Just like you found it.
Question 'C' appears (better wording would help) to ask to find the gain \$k\$ so that the magnitude (amplitude) of the ratio of the output, \$x(s)\$, to the disturbance, \$d(s)\$, is \$\bigg|\dfrac{x(s)}{d(s)}\bigg|_{s=j\omega}=0.1\$. That would mean that:
$$\bigg|\dfrac{x(j\omega)}{d(j\omega)}\bigg|=\bigg|\dfrac{1}{1+kG(j\omega)}\bigg|=0.1\tag 1 $$
So you don't actually need to find the Laplace transform of the disturbance because the only unknown now, is \$k\$—you can find \$G(j\omega)\$ from the bode plot and the frequency of interest is \$\omega=10\$.
Remember that the Bode plot gives the steady state response of a system to sinusoidal inputs, that is why you make \$s=j\omega\$ and in this case, you are getting an input sine wave. So by looking at the bode plot, you know what your output sine wave, after steady state has been reached, looks like. At \$\omega=10\$, the output wave will have a corresponding amplitude determined by the magnitude response of \$\frac{x(j\omega)}{d(j\omega)}\$.
From the bode plot, you can find the missing piece before you can find \$k\$, and that is \$G(s)\$ evaluated at \$s=j\omega\$.
$$ G(j\omega)=\dfrac{2.05}{\big(\frac{j\omega}{10}+1\big)^2}$$
With that (after plugging in the expression for \$G(j\omega)\$ in (1)), you can solve for \$k\$ in the expression at \$\omega=10\$:
$$\bigg|\dfrac{1}{1+kG(j\omega)}\bigg|=0.1 $$
And \$k\approx 9.68\$ (double check this).
I hope this answers your question.
  • \$\begingroup\$ Thank u for the explanation. I got a tiny question: where does the 2.05 value come from? \$\endgroup\$ – miguel747 May 2 '18 at 0:37
    \$\begingroup\$ @miguel747 It's the dc gain of the TF, in the bode plot is expressed in dB. Do you see the 6.25 dB figure in the bode plot? Convert that back to linear by finding 10^(6.25/20). \$\endgroup\$ – Big6 May 2 '18 at 0:48
  • \$\begingroup\$ Sorry for the wording confuse, There is a barrier language here and the problem was translate from the Portuguese. Ty again for the explanation about the dc gain. But How can u find the TF of the \$G(s) = 205/(s+10)^2\$? seems \$w=0\$, \$|G(jw)| = 2.05\$ (correct) and \$w = 10\$, \$|G(jw)| \approx 1\$ (correct). What the trick? Seems I must see the phase as well, right? \$\endgroup\$ – miguel747 May 2 '18 at 1:11
  • \$\begingroup\$ @miguel747 In your problem, they're only asking for the 'amplitude' in 'C' and that is given by the upper plot, the lower plot—the phase—tells you how much the output sinewave has shifted in terms of phase with respect to the input. It's my understanding that 'C' only asks for the amplitude, though. How you find the TF from the bode plot? I think you should probably read more on this online—this is whole new question. But this should help you find the tf from the bode plot: web.mit.edu/2.010/www/2010SpPS10Soln.pdf \$\endgroup\$ – Big6 May 2 '18 at 1:46
