I'm writing software (for ATMega32) that reads pressure from Bosch BMP280 sensor. I'm using I2C bus. I have found this library: https://github.com/BoschSensortec/BMP280_driver
and I have a question about inizialization of I2C:
int8_t rslt;
struct bmp280_dev bmp;
/* Sensor interface over I2C with primary slave address  */
bmp.dev_id = BMP280_I2C_ADDR_PRIM;
bmp.intf = BMP280_I2C_INTF;
bmp.read = user_i2c_read;
bmp.write = user_i2c_write;
bmp.delay_ms = user_delay_ms;
What function should I use as user_i2c_read/user_i2c_write and user_delay_ms?
The struct bmp280_dev is defined in bmp280_defs.h The actual memebers are
bmp280_com_fptr_t read;
bmp280_com_fptr_t write;
bmp280_delay_fptr_t delay_ms;
If you search further in that file for the keyword
bmp280_com_fptr_t
you will find this declaration
typedef int8_t (*bmp280_com_fptr_t)(uint8_t dev_id, uint8_t reg_addr,
    uint8_t *data, uint16_t len);
which gives that the functions you asking for are function-pointers. Here is a nice tutorial about function pointers. Programs as Data: Function Pointers
furthermore, it is essential to create theese functions and function-pointers, and to initialize a default return-value of rslt=BMP280_OK. Here is a shorted example from my own code. You have to implant routines to get proper error-checking-
int8_t user_i2c_read(uint8_t dev_id, uint8_t reg_addr,
uint8_t*reg_data, uint16_t len)
  printf("\nuser_i2c_read\n"); //just to see that the function executes
  int8_t rslt = BMP280_OK;
   // implent more code here, to a start you can print out the
   // variables.and check that they are are 'set'
   if (rslt != BMP280_OK)
      rslt = BMP280_E_COMM_FAIL;
   return rslt;
To the like for user_i2c_write and
void user_delay_ms(uint32_t ms){ usleep(ms); }
Thoose functions are called from bmp280.c . Also - when you from main run
rslt = bmp280_init(&bmp);
Without creating thoose functions, the bmp280_init will never give you the right return values.
Also it is worth mention that you do not need to name the functions to user_blabla. You can name them to whaatever you want - as long that you imitalize the functionpointers to the same name. That gives :you can re-initialize the function-pointrs to other names, and therefore make the read-call, the write-call etcetera to call other functions than they did previousley.
I might have some stuff in this to not be 100% accurate, because I just a few hours ago, after working many hours with this, found it out out myself, and I have been up all to many hours to get this working. And I am not naturally english speaking, so there we have the languge-barriar.
One last hint, the issues thread from the repo of BoschSensortec/BMP280_driver has some code worth looking at. BoschSensortec/BMP280_driver issuses
