Does anyone perhaps know what type of connector this is please? It's 8-pin but not a normal DIN connector. It's the remote control port for a peristaltic pump. I've asked the manufacturer for the connection type - they refuse to tell me, and only offer their own cable for £25 + c£100 in minimum order charges!
\$\begingroup\$ Do you have dimensions on it? What's the spacing between pins, overall size of the connector, etc? \$\endgroup\$ – Hearth May 2 '18 at 16:48
\$\begingroup\$ If you can take it apart, you might find a PN written somewhere. It will help to find the mating connector \$\endgroup\$ – Eugene Sh. May 2 '18 at 16:49
\$\begingroup\$ A brief search on digikey revealed these two connectors that it might be: [1] [2] \$\endgroup\$ – Hearth May 2 '18 at 16:55
\$\begingroup\$ Might be a twist-lock water-/weather-proof connector. \$\endgroup\$ – Ignacio Vazquez-Abrams May 2 '18 at 18:47
\$\begingroup\$ By the time you're done, their own cable will look like a pretty good deal. \$\endgroup\$ – Brian Drummond May 2 '18 at 19:00
Its the standard circular connector. Also know to the aviation guys as a "cannon plug" the 8-14 pin arrangement came in different diameter sizes. so you need to measure the diameter of the inner insulator (where the pins are mounted) so we can size it. Also there should be a part number on the backside of this connector which would be easier to source your plugs. the important numbers are going to be on the end of this part number (in example, a uts6jc12e8s is a size 12e 8 pin socket connector)
usually on panel mount connectors the part number will be stamped on the backside of the panel flange, so you will need to loosen the back mounting nut and pull the connector out from the front side and look for it with a little inspection mirror.
\$\begingroup\$ OK thanks drtechno. I managed to measure to insulator as 11.3mm diameter. You can't take the face off to get to the back of the socket without voiding the warranty. I will try this ebay.co.uk/itm/… \$\endgroup\$ – Oliver Walters May 2 '18 at 19:18
1\$\begingroup\$ I don't know, that key looks a bit large... \$\endgroup\$ – Ignacio Vazquez-Abrams May 2 '18 at 18:46
