I want to change shapes of and resize blocks/symbols to make the schematic tidier. For example, I want to make my multiplexers the shape of a trapezoid (like commonly drawn on paper) and make them smaller so they will be not as big as, for example, a CPU I have designed.
This is a problem because sometimes a multiplexer has to be added as an input to every pin of another block, then the whole design looks like a great big mess.
Is there a way to do those in Quartus Prime Lite.
  • \$\begingroup\$ try sending an email to Altera \$\endgroup\$
    – jsotola
    May 3, 2018 at 22:49
  • \$\begingroup\$ look through the program files .... look for png files, xml files, any files that contain xml info .... use a text editor like notepad++ to search the directory tree for words like XOR and NAND and MUX \$\endgroup\$
    – jsotola
    May 3, 2018 at 22:53
  • \$\begingroup\$ To see how they added shapes to the basic logic gates, you mean. I will try. \$\endgroup\$
    – E.Bülbül
    May 4, 2018 at 4:32
  • \$\begingroup\$ yes, the shape may be a picture as a PNG file (lossless format, no weird artifacts like with jpeg) ..... it may be defined in a text file (XML, some other extension) ..... maybe even an SVG file ............. or it may be built into the program and therefore not findable \$\endgroup\$
    – jsotola
    May 4, 2018 at 4:58
I don't believe so.
The schematic editor is essentially a toy. My understanding is that it is primarily included for feature parity with other software, and for introductory use in educational environments. It is not intended to be used for complex designs -- you are expected to use HDL in a production environment.
