I'd appreciate any help with identifying the connector in the photo below.
It's a button bar connector in a PSA (Peugeot/Citroen) car. Inside the brown shell there is a 2 x 5 2.54 mm pitch socket. The black thing is a lever which turns left on the brown pin when latched (the two extrusions to the right of the pin act like a part of a cog wheel against similar teeth inside the socket).
The imprinted letter seem to describe the type of plastic used, not the connector itself.
