Hello I am trying to improve my circuit schematic and I am looking for suggestions on how to make it more readable, I have read design rules on this forum and I am trying my best to follow them. The circuit is a light chaser that uses a digital pot that connects to a raspberry pi, that uses a voltage regulator to dim the leds if needed.
The voltage regulator has the highest voltage which is 10V, the 555 timer has 9 volts and the digital pot has 5 volts, so I placed the voltage regulator at the top, the 555 timer in the below the voltage regulator and the digital pot below that, The two other chips get 9 volts but seemed to work best at the bottom and the ground which is the lowest of the voltages is the bottom of the diagram.
