I want to design an ideal RLC oscillator that generates a sinusoidal voltage and current waverforms. To accomplish this I must provide the energy lost in the resistor. I want to do it from a DC voltage source as simple as possible (with a simple switch?).
How can this be accomplished?
  • \$\begingroup\$ This is usually done with an op amp, though the classic circuits (such as the Colpitts oscillator) use just a single transistor-slash-electron-tube. \$\endgroup\$
    – Hearth
    May 5, 2018 at 1:29
  • \$\begingroup\$ @Felthry I'm targeting power electronics, so a power solution will be better. And the analysis should be ideal, so if possible, completely avoiding the complexity of a real active element. \$\endgroup\$ May 5, 2018 at 7:50
  • \$\begingroup\$ Your above comment now makes the question unclear. Be very clear about your output requirements or add a power amplifier to a simple RLC oscillator. \$\endgroup\$
    May 5, 2018 at 8:17
  • \$\begingroup\$ You have no other choice - you must use an amplifier for establishing a positive feedback loop for the desired oscillating frequency (fulfilling Barkhausen`s oscillation condition). \$\endgroup\$
    – LvW
    May 5, 2018 at 8:54
  • \$\begingroup\$ If you want to make an inverter, this isn't the way to go about doing it. \$\endgroup\$
    – Hearth
    May 5, 2018 at 13:28
