This connector is part of a home built current controller I found. It is 20 years old. I know it's a long shot, but I am wondering if anyone can identify it, as I would like to use it. The only markings I can see on it are one the back side, it says "CXA" then it enumerates the pins 1 to 6. The outer diameter of the barrel appears to be about 0.7 inches.
  • \$\begingroup\$ That's certainly an odd one; I can't seem to find anything even close to it. The pin spacing is very strange. \$\endgroup\$
    – Hearth
    May 5, 2018 at 1:23
Looks like this type of circular connector.
"EN3® Sealed Connectors, 0.715" OD, 2-18 Contacts"
There's a similar series mini-CON-X here (page 10) which may be right, but the data is a bit sketchy.
  • \$\begingroup\$ Looks quite similar except the linked six pin version has a pin in the middle, unlike my connector. It's perhaps a start though. \$\endgroup\$
    – lhillber
    May 7, 2018 at 18:59
