I'm trying to use rfft function in STM32F407G and I am getting wrong results when I compare it with an online fft calculator . I give a sample input as {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32}. My results using the online calculator are as follows -
1)   528 + 0j
2)  -16 + 162.450726j
3)  -16 + 80.437432j
4)  -16 + 52.744931j
5)  -16 + 38.627417j
6)  -16 + 29.933895j
7)  -16 + 23.945692j
8)  -16 + 19.496056j
9)  -16 + 16j
10) -16 + 13.130861j
11) -16 + 10.690858j
12) -16 + 8.552178j
13) -16 + 6.627417j
14) -16 + 4.853547j
15) -16 + 3.182598j
16) -16 + 1.575862j
17) -16 + 0j
18) -16 - 1.575862j
19) -16 - 3.182598j
20) -16 - 4.853547j
21) -16 - 6.627417j
22) -16 - 8.552178j
23) -16 - 10.690858j
24) -16 - 13.130861j
25) -16 - 16j
26) -16 - 19.496056j
27) -16 - 23.945692j
28) -16 - 29.933895j
29) -16 - 38.627417j
30) -16 - 52.744931j
31) -16 - 80.437432j
32) -16 - 162.450726j
But the results using my code is completely different. I get the following result -
ffttestop[0]    float32_t   528
ffttestop[1]    float32_t   -16
ffttestop[2]    float32_t   -19.6766739
ffttestop[3]    float32_t   125.12075
ffttestop[4]    float32_t   -22.83638
ffttestop[5]    float32_t   46.0686264
ffttestop[6]    float32_t   -24.1503487
ffttestop[7]    float32_t   25.8768311
ffttestop[8]    float32_t   -25.7224121
ffttestop[9]    float32_t   15.1554413
ffttestop[10]   float32_t   -28.2019958
ffttestop[11]   float32_t   7.10556698
ffttestop[12]   float32_t   -32.8137932
ffttestop[13]   float32_t   -1.21792603
ffttestop[14]   float32_t   -43.8981056
ffttestop[15]   float32_t   -14.4978828
ffttestop[16]   float32_t   -96.4374313
ffttestop[17]   float32_t   -64.4374313
ffttestop[18]   float32_t   26.5798321
ffttestop[19]   float32_t   48.0752258
ffttestop[20]   float32_t   6.12293482
ffttestop[21]   float32_t   25.4729309
ffttestop[22]   float32_t   -0.353181839
ffttestop[23]   float32_t   16.9155769
ffttestop[24]   float32_t   -3.09499454
ffttestop[25]   float32_t   11.9728451
ffttestop[26]   float32_t   -3.78621292
ffttestop[27]   float32_t   8.55855846
ffttestop[28]   float32_t   -1.21792793
ffttestop[29]   float32_t   6.12293386
ffttestop[30]   float32_t   29.4866867
ffttestop[31]   float32_t   6.05591106
Here is my code -
#include "stm32f4xx.h"
#include "arm_math.h"
#include "arm_const_structs.h"
#include "core_cm4.h"
#define TEST_LENGTH_SAMPLES 32
*  Input and Output buffer Declarations for FFT
float32_t ffttestip[TEST_LENGTH_SAMPLES]=
static float32_t ffttestop[TEST_LENGTH_SAMPLES];
* Global variables
uint16_t fftSize = 32;
uint8_t ifftFlag = 0;
uint32_t doBitReverse = 0;
int main(void)
    //arm_cfft_instance_f32 * S;
    //arm_cfft_f32(&arm_cfft_sR_f32_len16, ffttestip, ifftFlag, doBitReverse);
    arm_rfft_fast_instance_f32 S;
    arm_rfft_fast_init_f32  (&S,fftSize);
    arm_rfft_fast_f32(&S,ffttestip,ffttestop,ifftFlag);
    //arm_cmplx_mag_f32(ffttestop,ffttestip,fftSize);
  while(1);
 return 0;
 /** \endlink */
What is the problem? I am unable to figure it out so it would be great if someone could help.
| improve this question | | | | |
  • \$\begingroup\$ I'm seeing float and complex number here. \$\endgroup\$ – Long Pham May 5 '18 at 14:35
  • \$\begingroup\$ yes..I read somewhere that the real part and imaginary part will be stored in alternate indices. \$\endgroup\$ – user3147192 May 5 '18 at 14:39
  • \$\begingroup\$ You should reverse-engineer the function to find out what it do. \$\endgroup\$ – Long Pham May 5 '18 at 14:53
  • \$\begingroup\$ yeah..I tried doing that but the algorithm for fft is really complex..I also went through the documentation here..keil.com/pack/doc/CMSIS/DSP/html/group__RealFFT.html \$\endgroup\$ – user3147192 May 5 '18 at 14:55
    \$\begingroup\$ No, if you go through the document, it says the output will return complex numbers. The FFT of real numbers can be complex. This is a quote from the document - "Looking at the data, we see that we can uniquely represent the FFT using only N/2 complex numbers. These are packed into the output array in alternating real and imaginary components: X = { real[0], imag[0], real[1], imag[1], real[2], imag[2] ... real[(N/2)-1], imag[(N/2)-1 }" \$\endgroup\$ – user3147192 May 5 '18 at 15:16
