I have used 8 bit microcontrollers and each of their ports has 8 pins. So, I thought a 32 bit microcontroller will have 32 pins in each port (i.e. 32 bit data bus). But today i saw STM32F070RB pin configuration and noticed that each of its port has only 16 pins (instead of 32). Why is that so? Am i missing something here or each port can have any number of pins (irrespective of microcontroller)?enter image description here
  • \$\begingroup\$ The processing architecture has nothing to do with how many I/O pins it has. Take a look at the ATtiny10 (microchip.com/wwwproducts/en/ATtiny10). 8-bit AVR microcontroller in a 6-pin SOT package, and two of those pins are used for power and ground. \$\endgroup\$ May 5, 2018 at 17:22
    \$\begingroup\$ Open up the datasheet and look at the block diagram of the internal architecture. \$\endgroup\$
    – Voltage Spike
    May 5, 2018 at 20:19
  • \$\begingroup\$ @BlairFonville No, I was responding to SHUBHAM \$\endgroup\$
    – Voltage Spike
    May 8, 2018 at 2:10
The simplest answer is: cost. More pins mean a larger, more expensive package. Since the number of applications which actually require a 32-bit port are vanishingly small, especially compared to the number of applications which might require 2, 16-bit ports or 4, 8-bit ports, no sane manufacturer is going to go that route.
Since the tiny minority can be addressed (usually) by driving multiple smaller ports, partitioning I/O pins into smaller ports makes excellent sense. Additionally, a processor with 32 I/O pins configured as a single port would be far less useful to most users than one with more, smaller ports. Such a device (a single 32-bit port) would occupy, and dominate, a fabulously small niche, and the manufacturer would lose money.
TL;DR - There just aren't enough people who want such a device to make it worth anybody's while to make them.
  • \$\begingroup\$ NordicSemi makes NRF5x with a single 32 pin GPIO port, and NXP LPC17XX has up to 32 pins/port, too. And those are only the two examples on top of my head. \$\endgroup\$
    – Turbo J
    May 6, 2018 at 17:50
STM32's port definition allow only 16 pins/port, because they re-use the upper 16 bits.
Look at how the BRR and BSRR registers work - the upper 16 bits have a complemantary function.
