Hi for some image processing purposes, I must read 12-bit color data of a pixel from Ram and display it on screen through VGA cable. However, my code does not read from Ram and all I see on the monitor is black square which should have been my picture. I tried reading from Rom and succeeded. I can read and display the picture from Rom but cannot from Ram. I tried everything I can but for 2 days I have not yet determined the problem. Here is the code segment I suspect most. What this code segment does is that it reads and writes data if signal done='1' and resets Ram from Rom if done = '0'. And also I must say that if enable is 1, I make write_enable 1 too. I constructed both Ram and Rom using block_memory_generator in Vivado 2017.2.
Reading_Writing_Resetting_Ram: process(clk,rst) is
begin
if rst = '1' then
done <= '0';
elsif rising_edge(clk) then
if done = '0' then
if address_rom <
conv_std_logic_vector((PICTURE_WIDTH_HEIGHT*PICTURE_WIDTH_HEIGHT),16) then
write_enable <= '1';
data_in_ram <= data_rom;
address_ram <= address_rom;
address_rom <= address_rom + 1;
if address_rom =
address_rom <= (others => '0');
write_enable <= '0';
done <= '1';
end if;
end if;
else --if done = '1'
if (pos_x < PICTURE_WIDTH_HEIGHT) and (pos_y <PICTURE_WIDTH_HEIGHT) and
(pos_x >= 0) and (pos_y >= 0) then -- if within picture
address_ram <=(conv_std_logic_vector((pos_x +
pos_y*PICTURE_WIDTH_HEIGHT),16));
if ( pos_x > cursor_pos_x - 1) and (pos_x < cursor_pos_x + length) and (
pos_y > cursor_pos_y - 1) and (pos_y < cursor_pos_y + length) then --if
within cursor
data_in_ram <= output_of_operation;
if enable = '1' then
else
end if;
end if;
end if;
end if;
end if;
end process;
Additionally
U3: Block_Rom port map(addra => address_rom,
                       clka => clk,
                       douta => data_rom);
U4: Block_Ram port map(addra => address_ram,
                       clka => clk,
                       dina => data_in_ram,
                       douta => data_out_ram,
                       wea => write_enable);
Additionally
    process (clk_in,rst) is
    begin
    if rst= '1' then --rst
    data_r <= (others => '0');
    data_g <= (others => '0');
    data_b <= (others => '0');
    elsif rising_edge(clk_in) then
    if (visible = '1') then --visible
    vgaData <= data_out_ram;
    data_r <= vgaData(3*COLOR_BIT-1 downto 2*COLOR_BIT);
    data_g <= vgaData(2*COLOR_BIT-1 downto COLOR_BIT);
    data_b <= vgaData(COLOR_BIT-1 downto 0);
    if (pos_y = cursor_pos_y and pos_x >= cursor_pos_x and pos_x <=
    cursor_pos_x + length - 1) then
    vgaData <= "111100000000"; --red
    end if;
    if (pos_y = cursor_pos_y + length -1 and pos_x >= cursor_pos_x and pos_x
    <= cursor_pos_x + length - 1) then
    end if;
    if (pos_x = cursor_pos_x and pos_y >= cursor_pos_y and pos_y <=
    cursor_pos_y + length - 1) then
    end if;
    if (pos_x = cursor_pos_x + length - 1 and pos_y >= cursor_pos_y and pos_y
    <= cursor_pos_y + length - 1) then
    end if;
    else --if out of picture
    vgaData <= "000000001111"; --blue
    end if; -- if within picture
    else -- if visible = '0'
    vgaData <= "000000000000"; -- black
    end if;-- visible
    end if; --rst
    end process SHOW;
The code above is used to set RGB values which is used in displaying
How can I solve this problem?
  • \$\begingroup\$ Did you make a testbench for your design? \$\endgroup\$ – Claudio Avi Chami May 5 '18 at 19:40
  • \$\begingroup\$ I think real problem is in the other question \$\endgroup\$ – runo May 5 '18 at 19:46
