I have been going through some past questions for my exam that is coming up this summer. I have come across this question which I originally deemed to be easy however the more I have looked over it the more I believe I am confusing myself and over complicating things!
This is the question I am looking at:
Question 1
My current thought process is that the voltage across Bulb A will not change when Bulb B is removed, however the current which previously was split between the two branches of the circuit (Kirchoff's Current Law?) will now all flow through Bulb A and its resistor.
This lead me to believe that if the current effectively doubles and the voltage stays the same then P = IV will mean that the power dissapated in Bulb A will also increase. This means that Bulb A is now brighter? and the answer would therefore be C.
I am asking if this thought process is correct? or if I have simply confused myself and gotten it wrong! If that is the case I would love for someone to explain the answer to me so I can understand it and attempt other questions like this.
Many thanks!
    \$\begingroup\$ Remember that you're working with a voltage source, not a current source. \$\endgroup\$ – Hearth May 6 '18 at 11:54
  • \$\begingroup\$ And please apply Ohm's law. \$\endgroup\$ – Long Pham May 6 '18 at 11:55
  • \$\begingroup\$ Remember the voltage across a voltage source (at least, an ideal one as drawn) is constant. The current through a voltage source is whatever it needs to be to maintain the terminal voltage constant. \$\endgroup\$ – Neil_UK May 6 '18 at 11:59
  • \$\begingroup\$ So if the voltage will stay exactly the same as an ideal voltage source then nothing will change for Bulb A regardless of whether Bulb B is removed or not? \$\endgroup\$ – Liam Carrington May 6 '18 at 12:05
This lead me to believe that if the current effectively doubles ...
It won't double. With a true (ideal) voltage source as shown in the schematic the current through each branch will be independent of the presence or absence of any other branch. (If the source were a current source then the result would be different.)
... and the voltage stays the same then P = IV will mean that the power dissapated in Bulb A will also increase.
Since V is constant and the R of the 'A' branch is constant (ignoring cold filament resistance on power-up) then I and P will be constant too. By substituting \$ I = \frac {V}{R} \$ you can rewrite your power equation as \$ P = \frac {V^2}{R} \$ and now it is clear that the power in each branch depends only on the supply voltage (a constant) and that branch's resistance.
Oops!
If the question shows up this year go for 'B'.
  • \$\begingroup\$ Ah I understand! Thank you i knew I was just over complicating it for myself, simply missed it being a perfect voltage source, thanks for your clear answer! \$\endgroup\$ – Liam Carrington May 6 '18 at 12:06
