I found this little gadget in one of my spare rooms in a bunch of old electronics and cords. I didn't make it and I don't know who could have. I've tried identifying it and nothing.
I put a little power to it and it makes a whinnying sound. I will take pics of it from outside then the board. Someone went to great lengths to close it up used a thick black composite maybe jb weld? I had to shave down and cut into the end in order to open it.
closed as not a real question by Kortuk Aug 6 '12 at 21:44
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, visit the help center. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ picasaweb.google.com/m/… \$\endgroup\$ – kymberli Aug 6 '12 at 13:56
    \$\begingroup\$ This link does not work. Please upload the image using the image upload function in the question editor. \$\endgroup\$ – Toby Jaffey Aug 6 '12 at 14:05
    \$\begingroup\$ maybe it's a horse? \$\endgroup\$ – markrages Aug 6 '12 at 17:45
    \$\begingroup\$ @markrages Beware, there may be Greeks inside... \$\endgroup\$ – Toby Jaffey Aug 6 '12 at 19:46
  • \$\begingroup\$ This is just guessing with no way to be sure with the amount of information given. \$\endgroup\$ – Kortuk Aug 6 '12 at 21:45
Often, components in power supplies will vibrate causing an audible hum. Sometimes, this is avoided by covering them with a thick epoxy or other potting compound.
If it is a power supply, great care should be taken when opening it.
  • \$\begingroup\$ picasaweb.google.com/m/… \$\endgroup\$ – kymberli Aug 6 '12 at 13:54
  • \$\begingroup\$ @kymberli The picasa links do not work unless the person viewing is signed into picasa - I personally just get a login page. \$\endgroup\$ – Adam Lawrence Aug 6 '12 at 15:40
