I'm new to PSpice and working on setting up my initial conditions for a capacitor and an inductor in a series RLC circuit. However, whenever I try to set up my initial conditions, the IC box is greyed out and I can't edit it.
The circuit I'm trying to implement is:
Any help would be appreciated!
  • \$\begingroup\$ I don't know PSpice, but in LTspice you can simply add 200u ic=0, right next to the value. WIll that work in PSpice? If not, is there a way to add the capacitor as a SPICE directive, instead of a graphical element? Something ike this: C1 a b 200u ic=0. \$\endgroup\$ – a concerned citizen May 7 '18 at 7:19
  • \$\begingroup\$ Rish, even if it's greyed it allows to initialize by double clicking on the box. \$\endgroup\$ – Pai Apr 28 '19 at 4:36
If it's at all like micro-cap or LTSpice you use a dot directive and place it on the schematic like this: -
.IC V(C1) = 1 or
.IC I(L1) = 2
I set this up in microcap recently for simulating a flyback controller: -
