I'm trying to build an analog synth. I'm reasonably adept in electronics but I have a problem. Its going to be a polyphonic so I want to have one pot controlling 4 oscillators because quad ones are expensive and I'm sure there must be a better way to do it. Is there a chip that could be used or is there something else I'm missing???
  • \$\begingroup\$ "cos" = "because" in UK casual use. \$\endgroup\$ – Russell Borogove May 6 '18 at 20:15
  • \$\begingroup\$ Please post a schematic of the design, it's impossible to say otherwise. \$\endgroup\$ – awjlogan May 6 '18 at 20:50
  • \$\begingroup\$ If they are VCOs then there shouldn't be a problem, just feed the same voltage to each. \$\endgroup\$ – Spehro Pefhany May 6 '18 at 21:41
Building a polysynth is quite a bit different chore from building a monosynth. Don't expect you can simply just take a mono synth voice, replicate that n times, and somehow magically wire them up as a polysynth.
The trick is that the voice has to be entirely voltage controlled, including all the static parameters that in a mono synth would be controlled by a simple potentiometer or a switch (switches would usually be replaced by a 4053 analog switch or a more modern equivalent). Then you use a microcontroller to generate control voltages and switch signals for the voices, and to read the keyboard, MIDI, digitize the front panel potentiometers and so on. As a free side-effect it's now quite trivial to implement patch storage on the micro.
If you do that naively, for \$k\$ analog parameters and \$n\$ voices you need \$kn\$ DAC channels, plus a bunch of digital outputs for the switches. As even a simple synth voice can easily have 20 parameters, for 8 voices you'd need 160 DAC channels! So the first thing you do is that you of course use just one channel to feed all of the parameters that are identical between voices (typically everything else except pitch control and envelope gates). This is why analog polys are typically not fully multitimbral. The second thing is that you use an analog multiplexer and sample-and-hold (such as a 4052, a hold cap and an opamp buffer) to generate the control voltages (if you're hand building a one-off instead of a commercial product, you might want to just splash out for a lot of multichannel SPI DAC's though, just to save up on soldering at the expense of a lot higher component cost).
By the way, you can probably see at this stage that writing the software for the microcontroller is not a completely trivial task...
In the modern day and age, your biggest challenge in the analog sense is to have an ADSR where the A, D, S, and R are all voltage controlled, without using a huge number of components per voice. Most modern polys solve this by having digital envelopes (but then this means that there's a DAC channel per voice for each of the envelopes, since their output will typically be different), whereas older polys typically had an ADSR IC. As it happens, such an IC is again in production, though it's not cheap: AS3310.
The details on how to do the multiplexing, converting typical monosynth circuits to complete voltage control and so on, are way too long for a EE.SE answer. However, you can get the idea, and a lot of inspiration, by studying the service manuals of the old classics, containing full schematics, many of which are readily found on google. Out of the really big names, at least the OB-Xa and Jupiter 8 schematics are immediately available. Note though that much of the details of the computer control can be done much easier today, since back then microcontrollers with integrated everything didn't yet really exist, so don't try to slavishly copy everything in these manuals.
So, to sum up: if you want to build a poly, you're signing up for quite a lot more than just replicating monosynth voices. However, it is a rewarding task, and if you want to pursue it I wish you the best of luck (and I, for one, would be interested in reading about your progress on a blog or such, if you're so inclined)!
|improve this answer|||||
  • \$\begingroup\$ @FinSmy Thanks! If you think my answer was helpful, maybe you could accept it as the correct answer? :) \$\endgroup\$ – Timo May 9 '18 at 9:02
The differences between a Quad pot and a single I can think of are two fold:
  • In a quad pot the load is only 1/4 of the single pot. This can be compensated by using a single pot of four times lower value.
  • If the destination is somehow injecting noise on the signal, on a quad pot this will hardly effect the other channels. In a single pot it will feed to the other channels. In that case you could use a a quad set of Op-Amps in 1x amplify mode. That will also remove the load from the pot but may introduce a bit of noise.
  • \$\begingroup\$ I'm curious about the type of pot you are describing. Can you post a link to a picture or datasheet for your 'quad pot'? OP, I think, was describing a 4-gang potentiometer. \$\endgroup\$ – Transistor May 7 '18 at 9:03
  • \$\begingroup\$ @Transistor I was talking about a 4-gang potentiometer but using the OP's nomenclature. What I understood he wanted to replicate a one-pot voltage divider, four times but on one axle, thus providing the same voltage four times to four different end-points. \$\endgroup\$ – Oldfart May 7 '18 at 10:47
Not the answer you're looking for?Browse other questions tagged or ask your own question.
