For same size and weight, will alkaline batteries last longer or shorter than lithium ion recharageable batteries?
I am not just talking about new batteries here. When I use lithium rechargeables I notice that they seem to quickly degrade and last for a lot less time than they did when they were new, so I am asking about typical time, in other words, after the device has been used for at least 3 months and been recharged at least 20 times.
For example, let's say I have a walkie-talkie with a rechargeable lithium ion battery. I use it for 3 months and recharge it 20 times. Will the device last longer, as long, or less long, than if it had the same weight of alkaline disposable batteries?
  • \$\begingroup\$ What was your average discharge time/10h (%), Depth of Discharge <10% (really weak) How much above 4.1 was the Charge Voltage? 0.1V typ. But not ideal or more (bad) What part number is it? ( got link?) How many cells of each? Ideally it should last longer until 200 cycles or so unless you can answer above. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 7 '18 at 12:50
  • \$\begingroup\$ @TonyStewartolderthandirt That is my whole point. I don't want to worry about things things depth of discharge. The reality is that I typically use things till they run of juice. I know that is "bad" for the battery, but that is the practical reality. I want an answer that reflects real life, not some of kind idealized fantasy in which people never deplete their batteries before recharging. \$\endgroup\$ – Tyler Durden May 7 '18 at 13:40
  • \$\begingroup\$ If you are wise do not equate my reality to yours and think about my questions and answer if you can otherwise your experience is an isolated case \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 7 '18 at 15:04
  • \$\begingroup\$ It’s like asking someone how often does the average person get tooth fillings or replacements when they don’t want to think about cleaning after a snack or meal., knowing that’s generally bad hygiene. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 7 '18 at 15:07
For the same size and weight, Li-ion can hold ~20% more charge than an alkaline cell. link. Since Li-ion provide a higher voltage, 4.2V to 3.6V compared to 1.5V to 0.9V, the usable charge is also higher.
  • \$\begingroup\$ And that’s for 1 charge cycle \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 May 7 '18 at 12:55
  • \$\begingroup\$ The question is about after the battery has been used for 3 months and charged 20 times. Assume that in many cases the battery was fully depleted before recharging. \$\endgroup\$ – Tyler Durden May 7 '18 at 13:42
  • \$\begingroup\$ It really depends on the battery, charger quality, discharge depth and lots of other parameters. A good quality cell, with proper charge/discharge protection can have 500 charge cycles with 90% charge level retention. An abused cell might last 3 charge cycles and be useless after that. \$\endgroup\$ – Lior Bilia May 7 '18 at 14:03
  • \$\begingroup\$ @TylerDurden: ROUGH estimate for fully depleted penalty is 1% per charge, so about the same. \$\endgroup\$ – dandavis May 7 '18 at 17:55
