I would like to know how one can read and obtain the outputs for Qa, Qb, Qc, Qd, using this data.
On the third line of the truth table, what does it mean when the outputs for Qa is a, Qb is b etc ? What are a, b, c and d ? Does it mean that the outputs follows the clock ? Why are the inputs for the load are a, b, c and d ?
Thanks
You've got it. On the rising edge of the clock (assuming the control inputs are properly set up) the four data lines (A,B,C,D) are transferred to the four corresponding outputs (QA,QB,QC,CD).
A,B,C,D are the four Parallel Data Inputs, pins 3-6.
Umm. I'm not sure what you're asking. They have to be something, right? Why not A-D? Usually data lines are referred to by alphabet letters starting with A. It's a convenient convention. Sometimes data lines, particularly for large data busses, will be called D0, D1, D2, D3, etc. But the IC you're looking at is old, and when digital ICs first started out they were relatively small and simple, so using letters rather than numbers was not an issue.
    \$\begingroup\$ "a~d: The level of steady state input voltage at input A ~ D respactively" it's right there under the table... \$\endgroup\$ – Arsenal May 8 '18 at 12:50
